Clogged Diesel fuel filter on W3eserbeke 10-2
279
Oday 272 Pensacola
Clogged Diesel fuel filter on Westerbeke 10-2
I'm assuming I have this problem.
Last couple times I have had diesel quit on me, but would always restart. Today cranked fine, went sailing for about 4 hrs, then tried to restart when wind died and was back in bayou heading to marina.
Cranked fine, would 'fire' sometimes, but normally just grind away on starter. I've had this 272 for about 15 months. Considered changing the fuel filter in the starboard lazarette, but found there was no filter in housing. Did not try to change filter on engine.
Bay was not choppy enough to stir up sediment in tank (if there is any), but have never checked for debris. Tank is approx half full of fuel.
Am I making this too simple? I'll find/check/replace filter on engine tomorrow. May purchase a 'water trap' type filter with see through bowl for 1st filter (vs Groco with no element). Is there an in-line filter, or just 2 'canister' type filters?
Should fuel pump run ALL the time key is on? When I had this problem, this is first time I've noticed it running...
Any other suggestions vs clogged filters?
Charles
'87 O'day 272
Pensacola, FL
279
Oday 272 Pensacola
Re: Clogged Diesel fuel filter on Westerbeke 10-2
Well, found 2 filters - one in fuel pump on engine, another in fuel filter on engine. Both appeared to have water in them - kinda of an 'emulsion'. Replaced both, turned on key to pressurize fuel sustem for at least 30 min. Tried to start engine, but wouldn't start. I DO NOT have a fuel shutoff or water separating fuel filter, so when changing 2 filters today, I have about a quart of diesel in 2 one gallon zip lock bags. Plan on installing a fuel shutoff and water separating filter. Any recommendations on either?
279
Oday 272 Pensacola
With what I believe to have been water in the fuel filters, should I be concerned with injectors? I won't be able to work on the Westerbeke for about 2 weeks, so need to know now if I have other problems...
Charles
May 27, 2012
1,152
Oday 222 Beaver Lake, Arkansas
If you have water in the filters and the engine quit, and wont start, you have water in the engine fuel system. Before you leave the engine sit two weeks, you should do as much as your able to clear the water out, reprime the engine and get it running. Water in the pump and injectors, not to mention what may have been sprayed into the cylinders, will do your engine no good at all.
Likely there is water in the tank/tanks, and it could be a lot. Rather than screw with them now, for the time being you can attempt to run the engine off a small tank, can, or bottle of diesel. Dump out the water in the filters and put in new ones, or reuse the old ones if your reasonably sure their clean. Run some fuel line from the filter into your bottle or whatever, and temporarily keep the return line going to the tank or dump it into the bilge. Running the electric pump or hand priming pump, some return fuel should come out the return line. Keep it running until its solid fuel clear of water. Keep adding fuel to your supply as needed. Once the fuel is clear with no water present, stop pumping. Crack the injector lines loose at the injectors, and again, with your supply filled, start the pump and crank the engine. Crank until you see fuel more or less free of water. A little wont matter, were just trying to get it running, the water will clear itself. But you need to see mostly fuel at the injectors. Stop cranking the engine, again make sure your supply is filled, tighten the injectors and attempt to start it. If the fuel return line is pumping solid fuel, put it into your supply bottle/tank. Run it as long as your able, but let it run at least 10 minutes so as to clear any residual water from the pump and injectors, and blow out whatever may have been pumped into the engine. Change the oil next time your at the boat.
If you cant get it running, before abandoning it I would advise removing the injectors, cranking the motor to blow out any water, and putting some kind of oil into the cylinders, and cranking again to blow out the excess oil and lube the cylinders.
Dec 27, 2011
279
Oday 272 Pensacola
Thanks AnchorClanker.
That's exactly the info I was looking for. I didn't know if the filters trapped all the water and none went into cylinders, whether water could foul the injectors, etc... I know manual says that if water is present in fuel, it can cause damage to engine...
If I get a tank (auxillary) of diesel, place fuel line on Groco in lazarette (easiest one to get to) and detach O'day fuel tank, assumng there is no water in Groco/fuel pump/fuel filter, should the motor start? I have no experience with injectors, gas or diesel. Can these be removed and cleaned? Or does it take a professional cleaning/replacement? Should the fuel pump run continuously even if engine is not running? Should it pressurize and stop, or is fuel continuously being pumped from tank to engine and excess returned to fuel tank? I know so little about diesel engines...
Thanks for your reply.
Charles
May 27, 2012
1,152
Diesels most often have engine driven mechanical fuel pumps, called lift pumps, to feed fuel to the injection pump. Others have an electric lift pump that runs whenever the power is switched on to start the engine. On engines with mechanical pumps there is often a manual operated hand pump incorporated.
The injectors are either screwed into the head, or clamped down with a plate and stud bolts. The later is the way most Yanmars are and they can be hard to remove if they havnt been out in a while. The filters trap debris, and can to a point separate water, but they will pass water once they get flooded.
If you can drain the filters of water and get fuel through to the injectors it should start. Again, loosening the lines a bit at the injectors will allow water, air and fuel to pass without being injected. Yes, the pump will flow fuel continuously. If you have an electric lift pump, it will be running constantly with the power on.
I hate the stuff and normally refuse to use it, but if I was going to be away from it for two weeks I would rather it ran first. I would do all the bleeding I could of water and if unable to get it to fire, I would try a lil bit of starting fluid. If you only spray it in while the engine is turning it will have the least negative impacts. Start with very small shots and slowly increase the amount until it fires.
You also need to close the sea cocks to the engine so it wont draw water back in though the exhaust. Keep it closed until the engine starts.
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
Be very careful. Starting fluid can fire off before the piston reaches top dead center and kick the engine backwards. Things can get damaged in the starter or worse if another cylinder is firing normally at the same time.
WD-40 is less likely to pre-ignite and will work as a starting fluid for diesels. It also has the advantage that, if the engine doesn't start, you will at least have gotten something in it that will help protect the cylinders from the effects of any moisture that is in them.
There are probably hours of reading on this forum if you do some searching?
Executive summary:
If your tank has inspection ports, the best thing you can do is empty it and physically scrub and clean it until it is as clean as new.
If you can't reach the insides, you'll have to spend a couple hundred bucks for a fuel polishing service to come and clean it. There are two kinds of these services. One just runs the fuel around and around through large filters, usually by tapping into the existing plumbing. These are just polishing your wallet. The service you want will use a suction wand that they can stick around into the tank corners and return the fuel with a pressure wand, sort of like a powerwasher, to blast crud off the tank sides.
Change your filters every year whether they need it or not. The elements get weakened and can leak.
I'm a big fan of onboard, full time, polishings systems. They need not be expensive. Mine keeps my system surgically clean:
http://www.cruisingonstrider.us/FOpolishing.htm
Dec 27, 2011
279
Oday 272 Pensacola
Thanks for al the tips and info. I was able to get a second set of filters (in case I needed them) at the Westerbeke dealership, and while there I asked about what I needed to do. So bought a 5 gal Diesel can, then purchases 2 gallons of diesel. Also purchased 6' of fuel line, and a product called 'Junior' that is supposed to help clean the fuel system. Can, diesel, fuel line, Junior, filters.
Removed fuel line from electric fuel pump and replaced with 6' fuel line. Took off filters (fuel pump and fuel filter housings) and cleared all water. Took out injectors and turned engine over 5-6 times. Poured a little Junior (half a capful) in each cylinder - figured if I couldn't get it to start, at least the Junior would help protect from water damage. Poured a little Junior in fuel can with 2 gal diesel fuel. Taped fuel line to my 'fuel meter' - 1/4" wooden dowel, and inserted in diesel can. Put it all back together, let fuel pump run for about 10 min and tried to start. Acted like it wanted to start, but didn't. Waited about 5 min for fuel pump to pressurize again and tried to start. Didn't want to start. Left key on with fuel pump running for another 5 min and tried to start. It kicked off and after sputtering for a few cycles, came to life. Ran it for about 10 min. Then did what I have heard is the cardinal sin for diesel engines - IT RAN OUT OF FUEL! I knew diesel engines returned fuel to the tank that it didn't burn, but had no idea that it would empty 2 gal of fuel in 10 minutes! Glad I didn't have the 5 gal can FULL of diesel! My regular tank would have overflowed! It had what I believe to be about 4 gal in it (along wiht some water), so now I have approx 6 gal of diesel to get out of the stationary tank.
But I'll handle that when I return - will be away from the boat for almost 2 weeks. Hopefully with running it I have resolved the water problem and will have no residual damage.
May 27, 2012
1,152
I am not a proponent of starting fluid, not at all. But as I said, if it was the choice between that or letting it sit two weeks with water in it, I would take the chance as a last resort. Also, as I said, small amounts only after its turning over. I havnt owned a can wd-40 since I worked around aircraft and heard (and saw) what it does.
Further, before using it as a last resort, I would have done everything possible to either get it running, or protect it, such as removing the injectors, clearing the cylinders and lubing them.
But at least it ran, and 10 minutes, while not a great amount of time, is enough you should be okay until you can get back to it.
BarryL
May 21, 2004
1,128
Hey,
Good job and it sounds like you are a competent mechanic and are learning a great deal.
One thing you need to know is that when the electric fuel pump is running it is pumping fuel from the fuel tank through the fuel lines and then back into the fuel tank. The fuel is NOT going through the fuel injectors, those flow fuel when the engine is being cranked over. So, if you have air or water in the fuel injector lines you need to either open the bleed valve (if there is one) or remove the injector lines and run fuel through them.
Now once you get the fuel in the tank cleaned, you can put the system back together, bleed the air out of the lines and the engine should start and run.
Lastly, I have a Racor fuel filter / water separator on my boat and it works very well. I would recommend you get one so this problem doesn't happen again. Oh yeah, make sure you check the o-ring on the fuel fill cap because if the ring deteriorates it can less rain and salt water get into the fuel tank.
Barry
Feb 4, 2007
81
- - Somerset,
I have the same boat and had basically the same problem but a different cause. Had injectors rebuilt after PO let the boat sit for 2 years. Replace all filters including one in lazerette. Still would not start. Fuel pump ran continously at high speed which is symptomatic of not achieving fuel line pressure. After much research found that cover on bronze filter/seperator in lazerette was not tightened sufficiently. Air was being sucked into the line at that point. Retightened that cover and pump went from high speed cliicking to slow rythemic click. Engine started after that. FYI there is a fuel shut off on the top of the tank at pick up line. The only wat to reach it is to lie on your back in quarter berth and reach up to the top of the tank or remove the instrument panel. I did that, removed the valve at that location and installed one just before the first filter in the lazerette.
Dec 27, 2011
279
Oday 272 Pensacola
Thanks Tedsbeds. I'll try your "to reach it is to lie on your back in quarter berth and reach up to the top of the tank" suggestion. I don't know that I have been able to SEE tank from qarterberth... Have cosidered removing bulkhead that separates q-berth & lararette, but did not see any screws that I thought might be holding it together... I'll probably get another valve & place in more convenient location, and a real water/separation filter. I know when I was looking in Groco for filter, that washer on one seide fell off, but seemed to not matter. While i have fuel shutoff would be a good time to find/replace IF I keep Groco in-line.
Thanks ALL!
Charles
