Clogged Diesel fuel filter on Westerbeke 10-2
I'm assuming I have this problem.
Last couple times I have had diesel quit on me, but would always restart. Today cranked fine, went sailing for about 4 hrs, then tried to restart when wind died and was back in bayou heading to marina.
Cranked fine, would 'fire' sometimes, but normally just grind away on starter. I've had this 272 for about 15 months. Considered changing the fuel filter in the starboard lazarette, but found there was no filter in housing. Did not try to change filter on engine.
Bay was not choppy enough to stir up sediment in tank (if there is any), but have never checked for debris. Tank is approx half full of fuel.
Am I making this too simple? I'll find/check/replace filter on engine tomorrow. May purchase a 'water trap' type filter with see through bowl for 1st filter (vs Groco with no element). Is there an in-line filter, or just 2 'canister' type filters?
Should fuel pump run ALL the time key is on? When I had this problem, this is first time I've noticed it running...
Any other suggestions vs clogged filters?
Charles
'87 O'day 272
Pensacola, FL
Charles
'87 O'day 272
Pensacola, FL
