Clearance under bridge
Jun 7, 2009
15
2 29.5 kingston ny
I have a 1994 HUNTER 37.5 legend. The mast height is 60’4” above the waterline. I need to get under a bridge at low tide and was wondering if anybody has any experience with putting weight on the end of the boom to heel the boat over to increase clearance distance. My understanding is on average of 5% lien gains a foot of clearance. I was thinking about putting 250 pounds in a Bo’s chair on the boom and swinging all the way over to Port.
Nov 20, 2025
28
Alden 60' Schooner Killybegs
It's pretty common technique. People that do it on the regular sometimes carry big heavy-duty water bladders and just scoop up some water for ballast. You can only heel over so far using the boom. Some people hang weight from a halyard and that has the added benefit that if you pre-mark your halyard, you know you are heeled exactly right when the halyard is on that mark and the ballast is just at the waterline. We had to do this once and borrowed some 50-gallon barrels for the job.
Your math is a bit off though.
With a 60.3' mast height and a 5 degree heel, you only gain about 2 inches of clearance. To lose a foot, you need to heel about 10 degrees. But to gain 2 feet, you only need about 15 degrees. And 3 feet only requires 18 degrees. If I only needed 1 foot extra clearance, I would aim for a 20 degree heel because the cost of being off by a bit is quite high. To achieve 20 degrees, you would need to get that ballast about 20 feet outboard which is longer than your boom. Even to get that first foot of additional clearance, you need to get that ballast out about 11 feet, which puts your boom at 45 degrees. Assuming you can deflect your boom about 60 degrees, the maximum clearance you can gain will be somewhere around 2 feet. That might be enough for you. It puts you at about 12.5 degrees.
Or you could try letting some air out of the tires.
There was a guy at the Indiantown Marina FL who did the water bags for yachts transiting the Okeechobee waterway. I've heard he died. But you can probably find a UTube video about it. He made it look easy but I would be pretty puckered. There may be a apprentice around.
Likes: BigEasy
Jun 11, 2004
1,927
Oday 31 Redondo Beach
You need something like this:
Apologies to those who have seen this many times before,
This website will calculate the heel angle you need
Input your air-draft for "c" and the bridge clearance for "a" and it will tell you the heel angle as alpha.
MFD
Jun 23, 2016
287
Hunter 41DS Pacific NW USA
I would suggest basic trigonometry to figure out the angle of heel you will need to reduce the air height of the boat to less than the bridge height.
if not on a lake, also adjusting the bridge height in accordance with MHHW from the charts and tidal activity.
For the heeling part, would strongly recommend testing that statically dockside in advance.
BTW - if you do this, and have time to collect some snippets of the prep work and actual transit under the bridge - definitely put it on YouTube or something. Would be fun to watch!
