Cleaningcockpit cushions
136
Hunter 45 CC Marina del Rey
Our cockpit cushions got brown due to dust over time. What is the best way to clean them?
Any ideas?
Thanks so much!
Viktor
Feb 10, 2004
4,232
Hunter 40.5 Warwick, RI
Mine are covers over foam and I have just power-washed them on a low pressure setting. I have done it both ways- foam in or out.
Nov 6, 2009
353
Hunter 37 FL
If they are covered with sunbrella, take covers off, wash in cold water washing machine gentle cycle and air dry. Ours came out looking like new. I also Scotchguarded them after they were dry.
Sep 5, 2009
136
The cushions have a foam inside on my Hunter 45CC. The covers are not sunbrella but look like a grid.
Hunter 29.5 Gloucester, VA
We scrubbed ours with Crudcutter and they came out great
Nov 8, 2009
537
Hunter 386LE San Fancisco
I suspect your cushion fabric is Marine grade Vinyl Textilene or Phifertex Sunsure. I have Phifertex Sunsure on my boat and clean it with West Marine citric deck cleaner, when required, while I am cleaning the cockpit. I will look into Crudcutter as an alternative.
Sep 5, 2009
136
We tried Curd cutter - works well. Need one bottle for one cushion!
Thanks to all!
Happy Thanksgiving,
Viktor
Nov 14, 2005
12
Hunter Hunter 38 Ventura Harbor, CA
Try Seabrite Inflatable boat cleaner - really a vinyl cleaner- and a green scotchbrite pad.
May 25, 2004
978
Catalina Capri 14.2 1670 Rochester, MN
I tried a green scotchbrite pad with mild soap. It left a green streak. The boat vinyl cleaner I tried left them dirty, slippery, and oily feeling.
I just starting using Clorox's new all purpose spray cleaner. Sprayed it on, scrubbed with a soft brush, and hosed it off. You could see the dirt wash away. Left them a bright white, like new.
