Cherubini 37, Stove Cavity
Nov 17, 2012
86
Hunter 37.5 Cherubini Bayfield, WI
We are not going to replace the broken Kenyen kerosene stove and instead will use the cavity for a storage system. Since my boat is 3-1/2 hours away from my home, could somebody give me the h x w x d dimensions of the cabinet?
Johnb
Hunter 37-cutter Richmond CA
I am considering that space for a fridge, with gimbaled stove top above it.
From left to right 22.25 inches
Front to back at the bottom 18/5" (the top is deeper due to hull slope)
Bottom top level with the counter top 21"
C&C Frigate 36 St. Margarets Bay, Nova Scotia
I am not able to get to the boat, but I measured the Kenyon stove I have in the garage and I imagine John's measurement is spot-on.
Mar 5, 2012
152
Hunter 37-cutter Saint Augustine
Hello just giving my two cents in I am not at my boat . but I removed the stove to and installed some metal shelfs like a dishwasher that slide out for pots and pans, and then made cabinet doors with louvers to cover home depot stuff it was pretty easy. I hope this helps going to boat now I will give you the size when I get back. my best Frank
Mar 5, 2012
152
23 w x 19 h x18 1/2 depth at bottom, 23 depth at top hope that helps
Johnb
Note that the aperture in the plywood facing is smaller than the dimensions of the fiber glass molding. My measurements were for the molding.
How about some pictures of how people have used that space?
