Check your batteries! Might not be the alternator!
Nymph
Nov 19, 2015
2
Marlow-Hunter 40 Newport Beach
2014 Marlow-Hunter 40 with Yanmar 4JH5E (54 HP & SailDrive SD50) and ElectroMaax 140a Alternator
My wife and I currently own the new Marlow-Hunter 40, hull #1, which we have placed in SailTime Orange County. We have had 2 years of relatively trouble free usage with just the normal wear and tear on the systems. We recently experienced an electrical issue that had several professional mechanics and myself flummoxed by the inability to correctly diagnose the situation. Our electrical system is comprised of two 4D AGM batteries serving the house systems augmented by solar panel system on the hardtop that was part of the Marlow Hunter 40th Anniversary package installed by the manufacturer on hull #1. The engine has a dedicated group 31 starting battery that is also augmented by its own solar panel also installed by the manufacturer. Both of these battery banks are maintained by a 2000 watt Magnum Inverter/Battery Charger and the typical 30AMP shore power supply.
While on a weekend escape, we typically will fire up the engine for about an hour in the morning so that we can make coffee, generate some hot water and allow my wife to use her blow dryer – gotta keep the wife happy! Well on the 3rd morning of our escape, I fired up the engine but noticed that the tachometer wasn’t working? Odd, we’ve never had an issue like that, but I didn’t really give it too much thought at the time. When I looked at the battery voltmeter, I was surprised to find the house system only registering 10.4 volts – this was after running the engine at an estimated 1500 RPM for about an hour and a half! Coming from an automotive background, my inside voice was saying, I really need to install an ammeter to be able to see what was really happening! But, we were headed home and I figured I’d dig into the situation there. The more I thought about things, I kept coming to the same conclusion – no tach, no charging, the alternator and/or regulator must be bad! Once back to our slip, I figured I’ll just take the alternator off, run it over to a local rebuilder and have it tested to believing it would confirm my thoughts. Well, the alternator tested fine but the electrical shop did not have the proper connectors or wiring diagram to correctly test the internal regulator. I decided just to call up ElectroMaax and get a new alternator and be done with it.
After having a new alternator shipped out, I installed it and everything seemed to be fine. The wife and I made a trip to Catalina Island to test out the systems and everything seemed good. Two days later, one of our SailTime members took the boat to Catalina and experienced a full blown electrical failure! I had the local marine repair guy dinghy over to the boat on the mooring to try to ascertain what was happening. Knowing that I had just installed a new alternator, he didn’t really dig too deep into the diagnostics but checked out the batteries and the voltage coming from the alternator and said everything looked good but in his mind, the alternator “must” have failed again.
I called up John at ElectroMaax and explained the situation. He was pretty damn confident that the alternator could not have failed. I reluctantly went along with his suggestions to perform further testing on the electrical system – focusing intently on the batteries and their connections. Needing to fly out for work, I had my mechanic do some additional testing while I was away. My mechanic assured me that the batteries were in a good state and all the connections were tight as could be. So say I was tweaked would be an understatement! I called up ElectroMaax to get a replacement alternator shipped out ASAP but said that I would perform some extra testing that John requested I do because he knew the alternator wasn’t the issue!! I ended up pulling the twin 4D AGM batteries out from beneath the sole of the cabin (no easy task!) and took them to a battery shop to have a full load test performed. As it turned out, one of the batteries had a cell that had shorted out and was debilitating enough to take down the entire charging system! Had the boat come with an ammeter, it would have made diagnosing the problem SOOO much easier!
If it hadn’t been for John Stephens and all the time and effort he put into helping me come to a correct diagnosis, I’d probably still be chasing that elusive “bad alternator”! As John kept telling me (and I kept doubting him!), if an alternator is going to fail, it will do so almost immediately! If the alternator appears to “fail” as I was sure mine did, there has to be another factor contributing to its demise!
I hope the saga that I went through and have described, and the tremendous assistance and concern that John and the rest of the ElectroMaax team provided helps others!
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
Glad to see you had a happy ending to all that. John does know his stuff, doesn't he?
Nice story. I sure hope you didn't replace the 4Ds with the same stuff. Not only are they bad for your back (!), they aren't rue deep cycle batteries. Have you considered golf carts?
Nymph
Nov 19, 2015
2
No, went with true deep cycle Lifeline 4D-AGM batteries. They have been performing flawlessly and are rated at 45 AmpHrs higher than the original set.
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
I added 2-190 watt solar panels and charge controller with remote display that tells me the batteries condition and also what is going on and my inverter/charge has a remote battery monitor also.
I have built in Gen so don't need any added charging alternator,but when the 2-4D's went bad changed to 4 T-105 6volt.
Nick
May 25, 2004
450
Catalina 400 mkII Harbor
when i replaced my 4d batteries i was able to install deep cycle, they were from interstate.
mike
Feb 6, 1998
11,772
The first test that should be conducted any time your batteries are dead, well beyond where they normally are during standard use, should be to:
  • Isolate all the batteries in the bank by disconnecting the negative or positive terminals
  • Test the voltage shortly after isolating them and write it down. If they had been wired in parallel then the voltages should be near identical or within .02V of each other
  • Let them sit for a few days and re-test the voltage
  • If the voltage reading is not the same, or within a few hundredths of a volt, then one battery likely has an internal failure, such as a short, which is causing accelerated self discharge.
An ammeter can't pick up on an internally shorted battery but could have shown you the alt was working. A volt meter can also tell you this. If your battery voltage increased when the alternator was turned on, eg: went from 10.4V up to 11V+ then the alt was working.
If you don't have an ammeter installed a DC clamp meter capable of measuring the largest loads on the boat should be standard equipment in every boaters tool kit. Heck the shipping costs and time you spent alone, mucking around with perfectly good alternators, and the loss of revenue to E-Maax for standing behind a product that was not defective, all would have been eliminated had the proper tools been employed..
This is also another prime example of why temp compensated charging is not only a battery health necessity but also a SAFETY item. With a 140A alternator and an internally shorted battery you got VERY, VERY, VERY lucky. You could have very easily created a thermal runaway condition and eventually a fire. A Balmar MC-614 would allow for a temp sensor on each of the two 4D's in your house bank. Strong consideration should be given to temp compensated charging and investing in a battery monitor or AC/DC clamp meter..
For a bare bones inexpensive AC/DC clamp meter the Uni-T UT204A at $39.95 is worth adding to any boat with an on-board electrical system.
Uni-T UT204A $39.95
JamesG161
Feb 14, 2014
8,108
Hunter 430 Waveland, MS
Wow nice price for a on board tool. Good tip.
I would have thought that a shorted cell would have not shown 12 VDC, ever.
Jim...
