Tim Dranttel
I've got a 86 TR with the M25 motor. I'd like to change the transmission fluid but cannot see an easy way to do it. I've got the suction tank so I think I can get the fluid out but do not see a way of getting access to put fluid back in. Also in checking the level I cannot find anything concrete in the owners manual about where the level should be. The dip stick has a line near the bottom and a small hole near the top. Right now the level is in between the two so I can't figure out which is correct.Thanks Tim
