changing that AIS boat name
Jun 10, 2019
57
Beneteau First 36.7 Marina Village, Alameda
Your AIS identity is tied to your MMSI. If you are a USCG documented vessel your MMSI would have been issued by the FCC; BoatUS handles MMSI assigned for US state-registered vessels.
Jun 13, 2020
34
Beneteau 37 Oceanis Keyport
I've done all that, but on chartplotters it still shows the old boat name. I think I need to reprogram the AIS transponder.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
That is inaccurate. I have had two USCG documented vessels, MMSIs associated with both, and both were administered by Boat US.
"BoatUS has been authorized by both the Federal Communications Commission (FCC) and the U.S. Coast Guard to assign MMSI numbers only to vessels that meet the following criteria:
  • Used for recreation only
  • Not required by law to carry a radio
  • Do not communicate with or visit foreign ports (i.e. Canada, Bahamas, Mexico & the Caribbean)
If you do not meet these criteria, you are legally required to obtain a Ship Station License from the FCC. They will issue an MMSI number with a Ship Station License."
BoatUS - MMSI Registration - Registration Criteria
jviss
Feb 5, 2004
7,090
This is also inaccurate. While there is a name associated with a vessel in the MMSI database, the AIS system does not access that database to display vessel names. The name comes form the AIS transponder. The installer or vessel owner or crew can access the configuration of the AIS transponder and change the vessel name and other data, such as "Vessel’s Type, Vessel’s Dimensions, IMO number, Relative position of the AIS unit, the Destination, ETA and Draught."
Here's the configuration screen for my AIS transponder, the vesper XB8000:
Here's a relevant page from Marintraffic.com:
Vessel details that can be changed in AIS transponders
jviss
Feb 5, 2004
7,090
does anyone know how to update the name of the boat in the AIS transponder?
Which transponder do you have?
You can change it in the transponder. You should also update it with the USCG NVDC if it's a documented vessel.
If CG wanted to encourage the use of AIS and corresponding MMSI #'s they could do a lot to simplify and clarify the process.
jviss
Feb 5, 2004
7,090
It's really not that complicated for US recreational users: you just go to BoatUS, create an account, apply for an MMSI, and you're done. You can even get an additional one, transfer one, delete one.
The only complication that I wish was simplified, or even made automatic, is that there's a difference between the BoatUS and FCC MMSIs. This is an issue if you venture into foreign waters.
Jun 13, 2020
34
I already had the prior owner contact BoatUS and release the MMSI and it is now assigned to me. At the BoatUS site, it has my name and the new boat name. It is a documented vessel, and given that BoatUS has it all correct, I suspect the problem lies with the transducer broadcasting the old boat name.
I have the SIMRAD NAIS-400 Class B transciever. All help appreciated.
Jun 13, 2020
34
Hey, it looks like if I can find the damn NAIS 400 unit, I can reconfigure it thru a USB cable with some software called proAIS that SIMRAD recommends. If it works, I'll post it here.
Nov 22, 2011
1,283
Ericson 26-2 San Pedro, CA
It is pretty easy. The only thing I'd add is that if you sell your equipment, be sure to wipe (or have wiped) the MMSI number. Otherwise, the new owner will still be broadcasting under the number that it tied to you and your vessel--assuming the new owner does get it changed, which he/she might not.
When I upgraded my Standard-Horizon GX1700 to a GX2200, I needed to take it in to Yaesu (who makes Standard Horizon) and have a tech wipe it because that model of radio is not user-modifiable. Other radios and equipment may be (such as the AIS transponder under discussion here). Either way, you want to be sure to take that step when decommissioning a pieces of equipment that you will no loner be using on your boat.
jviss
Feb 5, 2004
7,090
Yes, Alan, what I have done is transfer the MMSI to the new owner when I sold the old boat, and had the seller of my boat transfer the MMSI to me. You can also delete an MMSI.
Likes: Alan Gomes
Jun 10, 2019
57
I stand corrected, but still confused. For for MMSI tied to radio license issued to a person, not a vessel, does that mean to correctly change vessel name with an ownership change, that the transponder will have to be reprogrammed with a new MMSI issued to the new owner to separate it from the old MMSI associated with the old owner?
jviss
Feb 5, 2004
7,090
No, the MMSI is associated with a station, i.e., vessel, not operator. MMSIs can be transferred, so if you sell the vessel with radios, etc., that have MMSIs programmed, you can transfer the MMSI.
Jun 13, 2020
34
I figured it out. If you not sailing in international waters, your MMSI assignment can be managed by BoatUS. When the AIS trasponder transmits, it sends information that is programmed into it. For the SIMRAD NAIS 400, is was quite simple. Download proAIS2 from DigitalYatch and install it on your computer. Connect your computer to the NAIS unit with a USB/microUSB wire and open the software. You can reconfigure everything from there. Phew. One down, 3 to go.
