Hi all.
I'm planning to do an oil change and fit a new oil filter this weekend.
I think Steve Birch suggested that I use cheap generic engine oil -
are there any minimum standards that I should go for?
Also I plan to use a small siphon pump to pump out used oil through
dip stick hole.
Did I see someone suggest opening a drain nut under sump instead?
thanks,
John
Vega 1447 Breakaway
dip stick hole.
thanks,
John
Vega 1447 Breakaway
