Chain plate rework
Joey Taylor
I'm looking at a 22 that is for sale. The spreader stay chain plate is attached to a wooden bulk head that is damaged from leaks through the deck. Has anyone tried moving the chain plate attachement to the hull side?
Stu Timm
Can you rebuild the bulkhead?
Hi Joey: My 22 had a little problem on the port bulkhead chainplate. I bought four Shaefer 6" chainplates and drilled them out every inch or so and used them as extenders to the existing 2 inch long chainplates. The new chainplates overlap the existing ones, one on each side of each bulkhead (two port, two starboard), and extend 4 inches further down the face of the bulkhead, catching good strong wood. The bolts are run through the existing and new chainplates, and at the overlap. It beat having to reglass or fill the rotted section with exopy and it gives me a little more reinforcement in the chainplates. I have heard of these things failing and the masts falling on O'Day 22's. The cost of the parts was not very much at all and it took a few hours to do the work. Drilling out the new chainplates will take a hour alone. I am not sure about running hte shrouds to the gunwhale. O'day did not add any reinforcing there and the only area with blocking in the deck is where the chainplate is. Also changing the geometry of the shrouds and the chainplate location may necessitate getting a new set of shrouds made which can be costly. Good luck and hope that you can get some sailing in before year's end. Regards, Stu Timm "Karakahl" now high and dry! Centerport, NY
Jun 10, 2004
45
Oday 22 South Freeport, Maine
Bulkhead Repair?
I've had my "22" for 32 years..... If the midcabin bulk head is rotten....pull it out, use it as a template and cut a new one from suitable marine plywood. Also, replace the "U"s of the chainplate assembly witn new one from "Rudy" (look elsewhere one this site for the address). Good Luck!
