Chain Plate Help- & Shroud replacement ?'s
Paul P.
I have an 1977 Oday 25, and have just added a reefing furler. I also repalced all the turnbuckles on the rest of the cabling. As to be expected, the unexpected happened, and I need to replace all the shrouds because the turnbuckles are a little shorter, and some of the cable had to be cut to be used in the new fittings- to make a long story short, in the process of this fiasco, there was too much tension on starboard side shroud when the mast was being lowered--- this caused a bend to be placed in the chain plate where the two turnbuckles attach to the deck. In order to error on the side of caution, I am considering replacing the part. I could probably bend it back- it is stainless steel- and it is bent about 20 degrees. My problem is that I have been looking online and through West Marine, SAilnet, Shaefer Marine, etc, and have not been able to find the the part or a similar part. It is the peice with two holes in it for the two turnbuckles to attach. Any ideas about where I can find this part? Also, once I get all the shrouds replaced, what about tensions? Any suggestions on how to approach that? Thanks- Paul
Brian
Give Rudy a call
Rudy has them listed on his web page for around . The link is below. I reccomend calling in the order rather than just buying through the net, some model hardware is hard to get.
