Paul H
Took all my stern rail seats off and removed the wood slats. Used Amazon stripper at first(waste of time and money). When all the old finish didn't come off I started to use 280 grit sand paper. Worked fine.The wood was as smooth as a babies behind. Put my first coat of Cetol Marine on. Oh, by the way I was doing this in my basement (temperature about 50-60 degrees). it dried and I put on two more coats. Everything was going great. The wood looked great. Iwas really pleased for not having ever done this before. Well, I put the first coat of Cetol gloss on and let it dry 24 hours. Looked good. The second coat started to pucker and the grain started to come up from wood that I thought was perfectly smooth. The next two coats it got even worse. So, I took acetone to the wood got the finish down to where it was smooth again and started from scratch. Put a heater in the basement to warm the air up. The first new coat of Cetol gloss went on ok with a little bit of smudging(they look almost like finger prints). The second coat was ok. They turned out ok but not as bad as the first try. Any thoughts ,suggestions or help. I'm at a loss to think why the finish would develop this. Paul HS/V Linda Belle 95 H26
