Center board pennant exit hole in cockpit
Jun 13, 2017
17
Hunter 35 Legend Mobile, AL
I am a new owner of an old boat--1976 O'Day 25. The good news is that the centerboard was replaced shortly before I bought her. The bad? The plastic trim around the exit point for the centerboard pennant is broken and the line is sawing a hole in the fiberglass. Any ideas on what I can use as a trim piece to stop this before it gets bad, or is there a whole piece that runs from the line's entry into cabin through to the cockpit that should be replaced?
Thanks,
Carmen
Apr 26, 2015
663
S2 26 Mid On Trailer
Welcome CarmenK. If it's like an O'Day23, which I think it is, there is a plastic trim ring that slips into the hole. If no one else comes up with a picture by tomorrow I'll get one for you. Some of the O'Day 25 people will chime in shortly. You might give Rudy at D&R a call as he is the largest O'Day parts guy around. http://www.drmarine.com/default.asp
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
If I had to "buy" something, it would a stainless steel fairlead, roller, or the like. Is the pennant wire rope, or what? Do you have picture? It's "sawing" because it's got a variable angle (presumably in only one "plane"?
Jun 13, 2017
17
Thanks for your responses and questions.
The pennant is Sta-Set. I looked at some plumbing parts (through-hulls and drains) but diameters looked a bit narrow for the line and it would have to be modified someway. Securing it could be a problem-- the remains of the original is held with a screw. The boat is an hour away, so no pictures available right now.
Mar 31, 2013
234
O'day 23 Pa
mine must have got damaged years ago as it has a home made hardwood donut that works really well
