CDI Mainsail Furler on Hunter 28
Joe
Jun 1, 2004
8,360
You can single hand your boat easily without furling gear. You need to sit down and list your activities that normally require crew help... then figure out how you're going to do them without crew. First, the mainsail.... do like I do.. hoist it at the dock. Boat pointing the wrong way? Turn it around... get the sail up... just make sure the mainsheet and traveller are uncleated. 2nd..... the jib... easy peasy.. rig a jib "downhaul". Now you can bend on the sail before you leave, hook up the downhaul, and off you go. The dh keeps the sail securely on deck till time to hoist. Time to drop? Use the jib dh to bring down the sail right where you need it. For me, confidence in single handing was having a plan for each chore..... learn how to heave to, by the way.
You want to make a sandwich, or use the head? Or go to the mast... Install an autopilot, it's the most important addition you can make for singlehanding. If you have a tiller, they are inexpensive, wheel pilots... much more pricey, but, by far... the most worthwhile investment. The secret to effective auto piloting is to know how to balance your sails, it reduces strain on the device.
The 2nd most important investment is a harness and tether... and their habitual use. You never want to become detached from the boat when you're out by yourself. Period.
Growl
Oct 11, 2020
109
Hunter 28 2 Alamitos Bay Marina
Just got back from the boat again! I love my life! First thing I did when I got there was deactivate the clutch for the AP I don’t want some angry bottom cleaner diver snapping that plastic clutch ring while cleaning my Rudder. So, I figured out where the wheel brake is supposed to be installed, they routed the AP cables through the hole for the brake shaft! Lol! Do I really need a wheel break?
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
Yes. It will prevent currents, wakes, etc from driving the rudder into the stops.
:plus:Need the wheel brake when anchored at least. Helps when single handing for a quick sail trim. It was very foolish of the PO to remove it.
The Wheel brake is handy. If it can be reinstalled you find it useful. @Joe, has provided sound advice about being a solo sailor on board. (emphasis "staying on board").
Your discovery and protection of the AP will pay dividends in the long run.
No idea if this the one you need, but it shows that they are available.
Likes: Ward H
