CDI Mainsail Furler on Hunter 28
Growl
Oct 11, 2020
109
Hunter 28 2 Alamitos Bay Marina
My goal is to singlehand my new vessel! Has any donned a mainsail Furler on their Hunter fractional sloop?!
Likes? Dislikes?
Suggestions?
Thanks
Gregg
Lazy jacks are another way to handle a mainsail. You might want to research both options.
Based on this simple premise, why do you want to complicate your sailing.
While there are mainsail furlers on boats not all of them work smoothly or as advertised. There are owners that swear at them and by them.
It is said a main sail furler is wonder to be hold. That may or many not be true on a crewed boat. A stuck main sail furler on a solo handled boat is a night mare.
I single hand my boat, especially with new inexperienced sailors.
The mast is rigged so a trip to the mast to reef/shake out a reef, on the main is all on one side of the mast. Single point of control. Moving to the mast to reef also lets me assure all the boat is ready for the conditions causing me to reef. A sailor who says they never went to the bow and found a line loose or a fender left on deck, has not taken their boat off the dock much. It is a problem of human nature. I'll get that in a minute. A loose line in a blow is no fun.
Handling the sails at the mast means fewer line tangles, shorter halyards. Once you do it it is a simple task.
I do like a furler on a big Head sail (Genoa). There I did not skimp. I installed a Harken MkIV. They just work smoothly.
Before you spend money give the boat a try. Rig your main halyard, reef lines, and lazyjack lines all on one side of the mast for optimum performance. If you do not have lazyjacks that is a simple solution to handling a main sail as you drop it.
Spend your extra money on an Auto Pilot and sails. These I feel are more critical to single handling a boat than a main sail furler.
:plus:
On my boats I like to run the reef line back to the cockpit. If you can tame your genoa with a roller furler and tame your main with a reef line without having to leave the cockpit, you will feel a lot better. I also run a down haul on my main. With the reef line and down haul pulled, the main just sits on top of the boom mostly still while I deal with squal or orther issue.
Likes: Ward H
Catalina 320 Dana Point
I have a couple friends who have converted conventional rigs to furling mains when in their mid 80's in hopes of reducing physical tasks that were becoming more difficult. One used a CDI on a Catalina 270 with a carbon laminate sail with excellent shape, the other used a behind the mast system whose name escapes me on a PSC and adapted a dacron sail.
I'm pretty old but don't have much difficulty solo, what part is giving you trouble ? Raising the main is most physical demanding and I prefer to jump it most of the way at the mast then winch the last couple feet.
:plus: Keep the luff track or slugs clean and lubed should be a piece of cake. The hunter 28 only has 215sqft of sail. My Cal flys 259sqft and when into the wind you can haul the sail 80% of the way. Jump it the next 15 and only have a foot or so to snug up with the winch. Good maintenance will keep your boat easy and safe to sail.
Likes: Ward H
Growl
Oct 11, 2020
109
I understand, thank you, I would rather pull and retract my main than hoist, Previous owner just purchased a cross cut sail and leaves the reef in with flimsy lazy jacks.but that’s what I have at the moment I have used the CDI MR1 And was quite pleased. I have single-handed other sailboats but my Hunter 28 is my new challenge! As far as hoisting being the hard part I bought the winch tool that fits in the half inch chuck to a standard cordless power drill, can’t wait to use it!
I am still going to order the MR4/6 main Furler And try to have my rigger install it as soon as possible!
Sail on and have a good day
Sounds like a plan. Caution is advised with the power tool. It can be a great assist.
If the sail gets caught or the reef tie downs are not released, the power tool may not know to stop.
Then a visit to your friendly sail loft is the next stop.
Let us know how it goes.
Solo sailing is a passion.
Jan 7, 2011
6,017
Oday 322 East Chicago, IN
Both my Hunter 280 and my current O’Day 322 are equipped with a furling head sail, traditional mainsail with Lazy Jacks, and Autopilot.
I found both boats easy to single hand in this configuration.
I would say if you REALLY want in-mast furling, you should buy a boat so equipped. Trying to modify the mast and the sail would be a pain in the arse I would think. A boom furler might be added upgraded easier.
Greg
Likes: Ward H
Ward H
Nov 7, 2011
3,843
I don't relate solo handling to ease of handling the main sail.
I solo handle my C30 a lot. The trickiest part is departing and returning to my slip.
On the water a good auto pilot is critical for solo handling as are safe practices when working on the deck. Handling the sails is all about using the proper technique.
I wouldn't give up the convenance of a furling head sail so I can see the desire for a furling main sail but not from a solo handling perspective.
I'm curious as to the costs of the CDI MR4 system when installation and sail mods are considered? Furler = $2k, Install = $500, Sail modifications or new sail =$2k? So, $4-5K total?
Likes: Tally Ho
Growl
Oct 11, 2020
109
Auto pilot is absolutely a luxury, and new to me! When I had to leave the tiller helm on my other boats I would simply tye a half hitch,
If I lose auto pilot now do I lash the wheel in the same way? I agree with embarking being a little challenging but I can stuff that 28 in a needle! Absolutely MR4 increasing ease of Solo sailing! No hoisting, no reefing, no sail straps…. My Cal 25 had an MR1 and FF super easy solo sailing days Tally!
Yes, your numbers are close.
Steering pedestals often include a wheel brake to fix the wheel in position. Usually a knob either on the side of the pedestal or the wheel hub.
As David suggests, I use the wheel brake on the binnacle to temporarily hold the wheel in place. It does not do the job for very long. The boat will tend to drift off course. That is why I prefer the autopilot.
I have tied the wheel in place using a bungee or rubber tubing (surgical tubing). There is a little spring - to handle the bumps in the road but it tends to bring the boat back to the intended course.
Growl
Oct 11, 2020
109
Just got back from the boat I searched up and down the Edson pedestal and found no knob or locking mechanism only the engaging lever for the auto pilot do I just leave that on to act as a wheel brake or do I still need to lash like the old rudder days? Or at least so the diver can get good leverage when cleaning rudder? Lol!
6,017
If the AP is off or broken, locking the clutch will hold the wheel (generally) in place. But the gears and belt are plastic, so not the best way to hold the wheel (especially in rough seas).
I do use the clutch that way in a pin h…but I have a wheel brake too.
Greg
Growl
Oct 11, 2020
109
So the wheel brake is an add-on item or does it come with a certain model pedestal?
I would not use the AP to hold the wheel in the fashion you are considering. The Wheel element of the AP are not designed to handle that stress. It will crack the inner drive ring. Not a good thing. They are in short supply and cost $75plus :facepalm: .
I like your idea of a tie down and preferably with a springy line. Like a bungee.
