Caulking/ Adhesive
14
Hunter Vision-32 Puerto Vallarta MX
Good Morning All,
I have a 1991 Hunter Vision 32.
I am replacing the Lexan side panels with the portals in it.
I have removed the panels. The were secured with a black adhesive/caulking. Does anybody know what product was used ?
Or suggested another "black adhesive/caulk" product that can be used ?
Thanks
Richard
KD3PC
1,069
boatless rainbow Callao, VA
dow corning 795, make sure it is still in date and it does come in colors, so black should not be a problem. Anything else is a waste of time and money.
Can be purchased through commercial glass shops much cheaper than marine chandleries.
Rick D
Jun 14, 2008
7,208
You can also purchase it through the chandlery here and have it sent to you unless there is a local source in PV.
-na -NA Anywhere USA
Ditto on these suggestions. When you clean only use alcohol as acetone will damage lexan. You may want to tape around the area where to be applied on the outside and if you use your finger to smooth out, either use spit or alcohol on the finger to keep the caulk from adhereing to your finger.
crazy dave condon
Sep 2, 2009
339
Hunter Vision-32 New Hamburg, NY
Thinking of Doing the Same on my '90
Richard ... if you have pictures and any advice after you're done, it would be appreciated here!
