new owner of 1988 hunter 23, in removing stanchions this fall to cover boat, the old caulk picked up, and tore out a small piece of the fiberglass "glued" to the bottom of the stanchion. how to repair? and i am replacing tghe old teak hand rail on top of the cabin in same area. after removing the screws, the old teak breaks off instead of picking up, more of same old caulk, ( i assume this is old caulk, not white construction grade glue, looking for suggestions to loosen old caulk rather than ripping up more fiberglass am i correct in assuming it would be better to use a silicone white caulk when i replace stanchions? thanks for suggestions jim kerrigan
