Catalina Smile
Steve
What is the best way to fix the 'Catalina Smile", the crack between the hull and the keel?
Trevor - SailboatOwners.com
Fill, fair, paint
Hi Steve - I just used Evercoat to fill the crack, then faired it out and painted the area along with the rest of the bottom. No muss, no fuss. Best, Trevor
David
How to remove water
I recently filled the "smile" with West System Epoxy & filler. While the epoxy was hardening a few small bubbles of water appeared. I had opened up the crack a bit a month ago and made sure the bilge was dry, but there was still moisture in the keel. How do remove all the moisture? Thanks for any comments!
Richard
Keel stub
You may want to make sure your keel stub isn't gone too....
Steve
Thanks
Thanks Chris. I was talking to some other catalina owners who said I might have to replace the the wood above the keel. I wait till fall and see what it looks like when I pull the boat. I don't think there are any leaks yet. steve
Steve
I originally filled my "Catalina Smile" in 2000. When I hauled again in 2002 it hadn't reappeared yet, but I've heard it's common to revisit the gap every so often. Bottom line is that it usually isn't a structural problem, but it's definitely a good idea to stay on top of it and keep a close eye out. Best, Trevor
Steve
In the fall
Thanks Trevor, the boat's in the water already. I look at it in fall. I have a few rough spots on the bottom that need attention. This is my first year with the boat so I was anxious to get it in the water. no leaks yet. But I'll get after it before commissioning nest year. steve
