Catalina Boom Twist
704
Catalina 30 Sidney B.C.
Does anyone kn ow if the boom on a 1982 Catalina 30 will twist . I am installing a Boomkicker and the boom cannot twist
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
Mine does ...
My boom twists a little to the left. I heard that Bill Clinton had the same condition ... also it might have something to do with being right-handed. :D
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
What?? :confused: Please try explaining your question it makes no sense to me.... Why would you want your boom to bend or twist?
The boom kicker or a rigid Vang is just to keep the boom from dropping on someones head or dropping to the deck suddenly and doing damage when main halyard is released. Along with the obvious of keeping boom from lifting up and catching on the back stay during a jibe, accidental or otherwise.
Bob S
Sep 27, 2007
1,815
Beneteau 393 New Bedford, MA
My boom rotates easily. Have you tried removing it to see why it's not?
Jul 8, 2011
704
If you read boom kicker instalation instructions the say to make sure boom does not rotate at gooseneck and I hear older 30's no rotate
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
FWIW, my Capri 22 boom twists a little at the gooseneck but I'm not convinced it matters, mostly because I sail a loose footed main. If I used a bolt rope in the boom I might have a different opinion.
Oct 26, 2005
2,057
- - Satellite Beach, FL.
They are probably referring to an old style furling boom, where the boom was rotated, winding up the mainsail using a winch handle at the gooseneck for stowing or reefing.
This was an old system found on vintage boats that was dropped because it didn't perform as desired. There is a remake of this sytem with a cover over the boom and I don't see how this could be much better.
Jul 8, 2011
704
Found out boom does rotate ont he gooseneck so I had to order a bracket to make it solid
Nov 5, 2012
37
Catalina 36 Mumbai
Every boom can twist. Just make sure you don't apply too much tension or you may end up tearing your mainsail leech
