Catalina 30 engine access doors
Nov 15, 2014
137
Catalina 30T 5830 Green Bay
I am looking to remove the hinges from the 3 engine access doors and use different hardware to affix. I take the doors off every time I service so I don't step or kneel on the doors and bend the hinges.
I was thinking of creating a lip in the door bottom, and use some type of firm holding catch on the top. Would need to add a low profile handle to the door top.
Any other ideas? Any hardware suggestions? I was looking for a hinge that one can slide the door off of when open (similar to the hinges on our lazarette bench). Couldn't find any that would fit the current door/frame configuration.
Oct 28, 2013
114
Catalina 30 1978 #980 Catalina 30 1978 #980 Mission beach, California
mortyd
Dec 11, 2004
952
Catalina 30 easy living
also, as easy as the hinges bend, they unbend just as easily. just use an unbent hinge as a guide to see where the right angles belong.
Nov 15, 2014
137
Have rebent the hinges - that's easy. It's the hassle of taking the doors off/on. Plus with the doors open they are just an obstacle in the work area.
Oct 28, 2013
114
So what's wrong with my suggestion?
Oct 5, 2010
322
Catalina 30 mkII St. Augustine
My doors don't have hinges they have been modified as suggested and work great.
Oct 5, 2010
322
Not the best picture but you can see the doors on the left side of the picture and you can see the wood latch at the top of the opening. Picture was taking as we were preparing to lift the engine to replace the transmission.
Nov 15, 2014
137
<img src="http://forums.sbo.sailboatowners.com/attachment.php?attachmentid=84616"/> Not the best picture but you can see the doors on the left side of the picture and you can see the wood latch at the top of the opening. Picture was taking as we were preparing to lift the engine to replace the transmission.
That looks pretty much like my cabin when we were getting ready to hoist the engine to replace the transmission!! Did you place the door hinges on top of the doors, and did you make any mods to the doors or frames to fit the hinges? If you are using "take apart" hinges I would appreciate it if you could take pics of how you attached the hinges to the door and frame. I realize you may not be able to do that now, if your boat is wrapped up for the winter. Thanks!
Nov 15, 2014
137
Ok hvbaker - just checked your post again and you said you didn't use hinges! So, if possible, pics of the how you attached the door latches! Thanks!
Oct 5, 2010
322
Will take better set of pictures this weekend. I live in Florida. Boat is in water and will sail this weekend.
Nov 15, 2014
137
That'd be great! Lucky you - you get to go sailing instead of freezing your hinder off up here in WI!!
Nov 15, 2014
137
<img src="http://forums.sbo.sailboatowners.com/attachment.php?attachmentid=84702"/> <img src="http://forums.sbo.sailboatowners.com/attachment.php?attachmentid=84703"/> Hope you can see from these pictures.
Thanks for the pics!!
Feb 8, 2014
1,300
Columbia 36 Muskegon
I modified my hinges to make them removable. I cut the ends of the hinge pins off with a Dremel tool, and replaced them with machine screws (without nuts). Just pull the screws out and the door comes off. A cotter pin would also work.
May 7, 2011
241
Catalina 36 1430 Lake Lanier
Our hinges are on the top of the doors, no kneeling on them but a pain to keep out of the way. Cutting off the hinge pin and using a cotter pin is a great idea!
Catalina 380 16 Rochester NY
Velcro?
When I installed the house batteries under the nav table. I made a simple louvered panel to cover it. Originally, it was screwed in.
Then I installed velcro around it.
That was 3-4 years ago and it works fine.
