David Sandowich
I MOVED UP TO A 30 FROM A 27 IN JUNE. I KEEP THE BOAT AT A MOORING ON THE CHESAPEAKE . I BOUGHT TWO NEW BATTERIES. ONE A HEAVY DUTY CRANKING ONE FOR STARTING AND A DEEP CELL FOR ALL OTHER NEEDS. I ONLY USE THE CRANKING ONE WHEN STARTING THE ENGINE.WHEN THE ENGINE IS RUNNING THE BATTERY SWITCH IS ON " ALL". AFTER ABOUT A MONTH THEY BOTH HAVE GOOTEN LOW ENOUGH TO NOT BE ABLE TO TURN OVER THE ENGINE.I INTENTIONALY RUN THE ENGINE AND HOUR OR SO EACH TIME I USE THE BOAT TO CHARGE THEM BOTH SINCE I RARELY TIE INTO SHORE POWER. IS THIS TO BE EXPECTED? DOES THE ENGINE NEED TO BE RUN LONGER? HOW CAN I CHECK TO SEE IF THE BATTERIES ARE RECEIVING THE CORRECT CHARGE? ANY SUGGETION OR COMMON EXPERIENCES? THANKS
