Catalina is rolling out a new model at the Naptown Boat Show, the 275. Its a sort-of sportboat. Not really in the J70/J80 class but its probably going to be pretty quick for a Catalina. Here's Hull #1.
Fractional rig and self-tacking blade are part of a brave new world for Catalina, along with the fathead main and asm on a sprit. Should be quick on a reach but not great in W/L races where it is too heavy to plane.
It's going to be $80K, a shocker only for people that have not priced new boats lately. I think it will be fun, and give the First 25S a run for the money. With the short keel, its marginally trailer-able. I think it will do OK. More specs. What do you think?
Standard Equipment List
Construction:
Hull of Hand Laid Fiberglass
One Piece Fiberglass Deck
Molded in Non-Skid
Lead Keel with Stainless Steel Bolts
Five Year Gel Coat Blister Protection
Five Year Hull Structure Warranty
Water Line Stripe
Sheer Stripe
Spars and Rigging:
Full Batten Square top Main Sail with Reef Points, Sail Slugs, Class Insignia
Self-Tacking Jib with UV Protection
Complete Standing and Running Rigging
Internal Low Stretch Dacron Halyards
PVC Wiring Conduit with Messenger in Mast
Anodized Mast and Boom
Internal Outhaul Control in Boom
Sail Handling and Equipment:
Ball Bearing Mainsheet System
(4) Sheet Stoppers
Halyards Led Aft to Cockpit
Headsail Furling Gear
Single Line Reefing System
Rigid Adjustable Boom Vang
Mainsheet Traveler Located in Cockpit
Low-Stretched Dacron Sheets and Running Rigging
Head Area:
Sink in the Enclosed Head
Self Contained Head
Molded In Area for Optional Head
Opening Port
Paper Holder
Hanging Locker
Deck Hardware – Features:
Comfortable Cockpit with Contoured Coamings
(2) Cockpit Lockers
Fuel Storage Locker
Mooring Cleats (2) Fore and Aft
Molded in Anchor Locker
Stainless Steel Bow Pulpit
Stainless Steel Boarding/Swim Ladder
Manual Bilge Pump with thru Deck Handle
Self-Bailing Cockpit
Storage Pockets for Halyard Lines in Cockpit
Walk Thru Transom
Coaming Storage in Cockpit
Interior:
Private Enclosed Head Area
Solid Birch Interior Trim
Storage Lockers Under Berths
Main Cabin Table
Overhead Lighting
Fiberglass Hull Liner
Opening Forward Hatch
Fabric Covered Cushions in Cabin
Teak & Holly Textured High Pressure Laminate Sole
Electrical System:
12 Volt Electrical System Panel
Battery 12 Volt
Steaming Light on Mast
LED Lighting Throughout
Anchor Light on Masthead
Navigation Lights to International Rules
Engine
Yanmar 2 Cylinder 14 HP Diesel with Sail Drive SD 20
Option Equipment Available
Light Blue Colored Hull with white boot stripe and sheer stripes in lieu of Standard White
Single Point Lift Gear (to be able to launch from a hoist or Crane)
Performance Package
Asym Spinnaker with dousing sock or code Zero type spinnaker with furling system
Retractable bow sprit
Performance furling Jib with Vertical Leech battens and suncover
Cockpit cushions
Marine head with holding tank and deck discharge in lieu of std. self-contained head
Galley Stove
Speed and Depth Ray Marine
Offered with a Fin or Wing Keel
Trailer
LOA - 27' 6"
LWL - 26' 7"
Beam - 8' 4"
Draft fin - 4' 5" wing 3'5"
Sail Area 380 sq/ft
sail area 100% Foretriangle 265 sq/ft
Mast Height above the Water - 39'
I = 33' 0 J = 8' 5"
P = 31' 6" E = 11' 9"
Displacement = 4200 lbs
Ballast = 2000 lbs
Catalina 275 sport SKU: Catalina 275 sport Price: $74,850.00
Construction:
Molded in Non-Skid
Water Line Stripe
Sheer Stripe
Spars and Rigging:
(4) Sheet Stoppers
Head Area:
Self Contained Head
Opening Port
Paper Holder
Hanging Locker
(2) Cockpit Lockers
Fuel Storage Locker
Walk Thru Transom
Interior:
Main Cabin Table
Overhead Lighting
Electrical System:
Battery 12 Volt
Engine
Performance Package
Cockpit cushions
Galley Stove
Trailer
LOA - 27' 6"
LWL - 26' 7"
Beam - 8' 4"
Sail Area 380 sq/ft
I = 33' 0 J = 8' 5"
Ballast = 2000 lbs
