Cat 27 comments....
Hi Fred........ I've had my C27 about 10 years. It's a standard rig, outboard tiller steered, dinnette model. Go to the Catalina owner's association website, www.catalina27.org , and you'll find tons of info on the boat.My suggestion to you regarding your concerns is to sail the boat for a season before you start spending big bucks on unnecessary modifications. Converting to wheel steering is incredibly expensive and the return is questionable and it still won't provide that much extra space in the cockpit. Converting from end-boom sheeting to mid-boom sheeting is fine, especially if you want to install a bimini for that hot Texas weather, but it will make it a bit more difficult to single hand. As far as interfering with the motor, forget about trying to steer the boat with the motor... steer it with the rudder. If you don't have a remote control, order one for your OB. Probably set you back three or four hundred bucks but well worth it. Other wise prop the hatch open and angle the tiller handle up so you can reach it. I would consider putting an extension on the shift lever so you won't have to fumble around to take it out of gear. I'd make these mods whether the traveler is on the cabin top or in the cockpit.Regarding the winches.... that's called tailing. You must "tail" a winch to make it work. They make "self-tailing" winches... a common upgrade on older boats... they'll cost you about 800 bucks apiece. So...try this technique for the meantime; When you start a tack, stand up, facing forward and steer the tiller with your knees while you control the sheets with each hand. The new sheet should have a couple of wraps on the winch drum. Don't release the old sheet right away, wait for the sail to backwind a bit to help turn the boat, then cast it off by pulling straight up on the line. Pull the slack with the new sheet, but don't haul the sail across, let the wind push it as you remove the slack. You can now use both hands to strip in the new line. You should be able to get most of it in and still control the boat. When you fine tune the sheets, learn to tail with one hand and ratchet the winch with the other or head the boat up a little and trim the sheet in by hand when the sail starts luffing. All this is easier if you have a way of temporarily holding the tiller steady. i.e. auto pilot, tiller tamer, two pieces of rope etc.Before you go purchasing wheel pedestals and a new mainsheet system, I'd recommend spending money on an autopilot, remote control for the OB, new rigging and new sails. To make single handing easier make sure all lines lead aft. Make sure you have an extending boat hook and that you buy and wear a safety harness with tether. Also, if you don't have roller furling... rig a jib downhaul so you can get the headsail down easily without going forward. Finally, think about how you would get into the boat by yourself from the water. I have a lanyard on the folding ladder attached to my boat's transom so I can pull it down from water level
