My M25XPA vibrates badly at idle, in or out of gear. I've replaced the engine mounts & injectors and had the marina tech verify that my idle is set to 1000 RPM using a digital tach, all to no avail. Someone mentioned that I should check the Damper Plate, so, having nothing better to do on a cold January day I decided to pull the tranny and have a look to see if there was an obvious problem. Aside from a little bit of wear on the splines I don't see anything amiss.
Does anyone have any advice as to what to look for in a damper plate?
