If the discussion is about the base mast step, it would not need 2 pins I would not think. One reason sailors only use 1 pin is to be sure and not forget and then try to lower the mast with the forward pin still in. That will damage the foot unit. As long as you have shroud lines all around and snugged up, the mast will work fine with 1 pin. It isn't going anywhere! Chief
