on my capri 26 is the water tank at the rear of the cockpit the one that feed the hot water heater or does the one under the sette feed hot an cold? mabey one at rear is spare? does anyone know.... help!! thanks, Glenn
Under the cockpit on port , you should have the water heater, in the head , in the bottom , your holding tank. on starboard , under the sette is your clear water tank that
provides water for both cold and water heater. Hope that helps.
