Capri-26 Help
2
Catalina Capri 26 Solomons MD
I'm very close to purchasing a 1991 Capri-26.
Does anyone have an owners Manual/PDF that they could send me?
I would also like to know the size of the winches, This boat has (4)
Thanks
Casualobservertwo@msn.com
May 7, 2006
249
Catalina 28 Mark 1 New Bern
I had the capri 26 with the inboars diesel andb loved it. I thought I wanted a larger boat and traded up to a cat30. 8 wish I hadb stayed with the capri not because the 30 is a bad boat just because the 26 is such a good boat.m bi would buy another one if I was in the market. What part of the owners manual do you need I may have it.
May 7, 2006
249
Sep 9, 2011
2
Hi
I was thinking of moving the traveller from the cockpit, anyone know of any instructions. Also is it worth doing give that the main sheet will be further away above the cockpit?
Thanks
Scott
Oct 10, 2011
76
CATALINA 28 MK II MONTREAL QC CANADA
Hi
Thanks
Scott
to be able to install a dodger, i had to move the traveller 10 inches forward . i had to raise it up a little with some shims. of course the pressure will be increased on your sheet . you might need bigger blocks to go with it but i did it and i don't regret it.
