Jim
I wonder if anyone else has seen this problem? I can't remove my old fan belt because the engine seems to be mounted to far forward and the space between the belt pulley and the fiberglass wall of the bench seat is too narrow. Could the engine be working its way forward over time...or was it just mounted too far forward to begin with? Should I have the engine moved backwards (and realigned) or should I just try and cut away some fiberglass?Thanks is advance,Jim
