Can a mast be repaired? If no, where can I buy a mast for my Hunter 23.5?
May 12, 2025
29
Macgregor 22 Silverton OR
I'm inclined to blame ego driven welders that have well fed lawyers mostly because I'm a cheap sailboat owner that can't afford a Death-Star lawyer. (probably wouldn't even if I could)
... It's sad that due to "Liability" reasons, welders don't want to repair the mast...
I think it's more than liability. Any skilled person would not want to apply his/her skill to a job that will fail. Of course they don't want the liability but moreover a skilled person doesn't want his/her reputation to be questioned and doesn't want a customer to come back for a re-do at no cost or reduced cost. The one choice a skilled person has that affects the bottom line is what jobs to take and which ones to pass on.
-na -NA Anywhere USA
Dwyer Aluminum and Z Spar are two seperate companies. ZSpar left the U.S. but re-emerged as U.S. Spars. As a Hunter dealer, I gave the original design for the 23.5 to Hunter and worked closely with the mast designer who designed the 23.5 mast. Having introduced this boat, I sold appx 20-25% of the production line and assisted the warranty department.
when I saw the crack in the mast, I observed a three sided rectangle around the spreader bar attachment on three sides located in very critical area of the mast. The side wall is no longer level with mast as it appears to be pulled out. This is why I recommend another mast. It has nothing to do with lawyers and welders. By the way, I had shown this picture to two retired mast designers who concurred with me.
If anyone wants to be cheap trying to repair such a crack by welding, please let me know so I will not step on board due to safety
Feb 22, 2025
16
Hunter 23.5 Navarre
I bought a new "mast section" for $2850 and moved everything over from the cracked mast to the new mast. All it took was a Dremel, drill and rivet gun (and elbow grease). A lot of precise measurements. The quote from Z-Spars for a new mast was about $4000 with shipping.
3,554
Not sure why that would concern anyone. A lot of work for $1150 but you know that mast better than most anyone else knows theirs now.
