K
Kevin
I am thinking of getting a Campbell Sailor 3 blade for my CS27 (27 foot sloop, 6,100 pounds, Yanmar YSE8 8hp diesel) to replace the 2 blade fixed prop. According to their web site the Campbell will eliminate my prop walk in reverse, give me a higher cruising speed at lower rpm (currently I get a max of 5 nmph on flat water), and generally run smoother due to the 3 blade being less affected by turbulence from the keel. If you have a Campbell I would appreciate your feedback.Thanks,Kevin BennettToronto
