Cabin windows C30 - 1981
Ron
Hi All, Like most C30s of this vintage, a couple of my windows leak. I would like to upgrade them and I'm sure I saw a retrofit kit listed somewhere but I can't seem to find it. If anyone knows a web site (or two) that lists this type of thing I would sure appreciate it. Thanks.
Jack
mine leak also
I have Two windows that drip was going to remove them and re coulk was this a poor design or product #1559 ?
Denny Fegan
Easy to fix
Ron, The windows are relatively easy to fix. You have to remove them, clean up the old bedding compund and rebed with marine silicone. the trick is to form a bead with the silicone, insert the window and use small shims (I used some small bolts)to center the window DO NOT TIGHTEN THE SCREWS ON THE WINDOW FOR 24 HOURS (unless you use a heat lamp). this will form a gasket and you can tighten after the silcione cures. Best, Denny Fegan
don
cruising concepts
i believe cruising concepts has the window kit you mentioned- they are the black plexi- makes an old boat look new.
don
cruising concepts
L
Lou
leaky windows
The windows on my 1983 c30 also leaked, but the leak was between the glass and the metal frame, not between the metal frame and the fiberglass cabin trunk. My fix was to dig out the old silicone, mask off the aluminum frame and the glass and then caulk with new silicone. This worked well. Also found a leak where the aluminum seams together on the outside of the frame. A little silicone solved this problem also. I guess what I'm saying is, before you pull the whole window make sure you know where the leak is coming from. If you pull the vinyl strip on the inside of the window and there is water in the track, chances are your leak is between the glass and the aluminum frame.
L
Lou
leaky windows
jchealey
leaky windows
do yourself a big favor and save yourself a lot of greef,go to catalina direct.com and order vinyl glazing channel kit for a cat-30(34.95) its the only perm fix that works and it looks original
jchealey
leaky windows
