Hello everyone,
I’m trying to locate the ground lug, strap or location. I lost my cabin lights. So I started checking voltage and showing about five volts. I suspect it’s a corroded or dirty ground. But I started tracing circuit from breaker and the black wire (- ground) is in the wire bundle with cabin, running, steaming lights. So I’m thinking the black wire must connect with a common ground point. Obviously I’m going to do some more investigating.
but I’m thinking why wouldn’t the ground connect directly with the battery ground? The batteries are directly below the circuit breaker panel.
thank you in advance,
Ed Garcia
Ed Garcia
