Ch Ch Ch Changes...
I have noticed the revised information that appears on the Catalina Yachts C310 website. As to the actual specifications, some of it seems to be updated, like the engine HP, sail area, and holding and fuel tank capacity. Some of it I know is plain wrong, such as engine size (61 cubic inches for the B engine), and fuel consumption. Also, mine had double spreaders not single, a 15 X 10 prop not 15 X 9. And they must be calculating the sail area/displacement with actual area of the 135% jib and not 100% foretriangle, which is customary.Malcolm, I assume you are referring to the redrawn interior layout of the cabinets against the hull in the galley area, and the detail changes (?) behind the settees.In light of the previously mentioned points and my previous experiences with Catalina marketing materials and their accuracy, there may be some changes coming but I wouldn't get too worked up about them yet. Please let me know what you hear from Catalina. I will be checking out hull #104 if it arrives at my local dealer soon (as expected).And yes, I thought about all that water sitting in the hot water tank the first time my main tank went dry on a cruise. The specifications should not list hot water in the total capacity, but as an additional item to avoid being misleading. On the bright side, a lot of other 30 to 40 ft boats don't have a large enough hot water capacity to make much difference!
