This is a topic I've not seen on this website. I have a 1986 C27TR. The front forestay is anchored to the bow via a stem. This is a metal bracket approx. 6-8 inch below the small bowspirit on all Catalina TR's. It has 3 heavy bolts, bolting the bracket to the bow. The bracket is starting to pull away from the hull.
I've gone inside the boat and removed the small wooden bulkhead right behind the anchor well. As expected, the bracket has a wooden backing plate with a additional (but smaller) metal backing plate. Water has gotten to the wooden backing plate, it has begun to rot and needs to be replaced.
Has anyone preformed this repair. Nothing technical. Pretty straight forward.....except, I'd like to do this with the mast up. Has anyone done this job?
