C25 vs C27 Performance
H
Hoss
I would be interested to hear from anyone who can comment on the differences in sailing performance between the C25 and C27. I have lots of C22 experience but basically none in 25s or 27s. Thanks, Hoss
Rob
Hmmm.
Cadillac vs Oldsmobile. Both are great, one is a bit better. If you get a 27, look for a Tall Rig. Best of Luck, Rob
Bob Camarena
C-27 By Far
The C-27 will sail a lot better. The C-25 is a compromise since it was made to be trailerable. It's a fine boat but doesn't compare to the C-27 in sailability or livability. Most prefer the outboard version of the 27 (check the archives) and the standard vs. tall rig will depend a lot on where you sail. If you have a lot of high winds (like SF Bay), the standard rig will be fine and you won't have to reef as often. Otherwise the tall rig is probably the better choice. You can always shorten sail, but you can't make them bigger.
