c-30 rigging
C
Chuck Lennox
I am presently in the hunt for a 78-83 Cat30. I see a lot of boats that have replaced their mast,booms and rigging. I see many that haven't. I can understand the rigging, but is there a problem with the masts and booms on the older boats? I will certainly get a survey prior to buying. Thanks Chuck
Ron
Mast Replacement
I don't think the spars are "wearing out" and I have not heard of many problems. I recently painted my '83 Cat 30's mast and boom. The anodizing had deteriorated and I had corrosion around all the fittings. Most replacements that I have heard are from corrosion around the base and anywhere stainless steel and aluminum had contact. Around the spreaders, mast top, and fittings. Standing rigging should be checked with dye to look for crevis corrosion. My boat still has the original rigging, but it is recommended to replace it after 10 years. Check the thickness of the extrusions and if it is not too thin or badly corroded then a good prep and paint job should last many seasons. Fair winds...
Todd Osborne
Check the Mainsheet Outhaul
I've seen a few booms with the Mainsheet outhaul frozen. I believe there are some internal pulleys that freeze up. The stainless fittings seize up against the aluminum boom.
