Hello.
Thank you for your consideration.
Here's whats happening and what I have done.
When perko switch is on #1 battery, the cabin lights are much dimmer than when I switch to #2(the starting battery.) My first thought was that battery #1 was not charging as well as battery # 2. So I took out both batteries and had them tested, both were fully charged. So then I figured it must be corroded battery terminal. So I cleaned them and reinstalled. I Still have the same problem. Any insight is appreciated. Now at least I know I wont get caught at sea with a dead battery
Thank You, Buzz
Thank You, Buzz
