Let me add to Rick's comment.
Rick has accurately defined the term. i'd like to encourage you to learn how. I assume you already know how to accomplish a gybe safely.Always operate on the premise that anywhere within five degrees of dead downwind is a danger zone and particular care is required of all aboard. While in this zone, an accidental gybe can result from a moment's inattention. Also consider dead downwind as being the start of 'by the lee'. That said, in winds of less than ten knots, you can learn to sail by the lee safely. First, don't try it short handed until you know what you doing. Make sure that everyone on board is aware of the risks and paying attention. A flying boom can kill if makes contact with a skull or neck during an accidental gybe, even in lighter winds.Put a 'preventer' on the boom. In light winds, this can be accomplished by moving the lower end of your boom vang from the attachment near the mast base to an attachment on the windward (boom side) rail. This practice can result in a broken boom and may bring down your rig during an accidental gybe in a stiff breeze. The safer practice is for the preventer (same hardware as a boom vang, just more line) to be hooked to the end of the boom and to a solid, secure attachment as far outboard and just aft of the mast as possible.I've been sailing for over 35 years. IMHO, sailing by th lee in winds over 10 knots should be left to experienced racing crews that can afford to replace their rig at whim...but then, I'm not crewing with them as it's still too dangerous for me. I've seen one accidental gybe in 25 knot winds without a preventer and the unbelievable force and speed of the boom swinging over guarantees that I never want to see another. A knockdown caused by a 15 knot gybe, with a preventer, guarantees that I will never hear the end of it. (One hard and fast rule of the sea... never disturb the Admiral's equilibrium!!!)If you must sail directly downwind, drop your main. The extra knot of speed is rarely worth the hazard or angst unless it is for a short period of time and in light air.When sailing with the wind, it is my usual practice to sail about 15-20 degrees off the wind. It is usually faster and, around here, much cooler in the summer. If I am shorthanded (which is most of the time) I am more likely to do a '330' tacking back through the wind than a gybe. My philosophy is that the tack's lower probability of a screw-up mushrooming into a disaster makes me happier than the saved time a gybe engenders.Regards,
