Bulkhead Repair
Jun 12, 2010
1
Calalina 30 norwalk
Leaking shower caused damage to bulkhead under table seat. Damaged area approx. 18" wide by 12" high. Is this bulkhead structural? Looking for suggestions for a repair process.
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
Are we talking about the main bulkhead that has the port chainplate and abuts the compression post?
From the size of the rotten area described I would replace it on my boat. Use the old as a template and get a good marine plywood.
Mar 20, 2012
3,983
if it sets under the mast you can bet its a very importent structural component of the boat.
Nov 8, 2010
11,386
True bulkheads are by definition structural. On sailboats they can support the standing rigging, the mast compression, and also add rigidity to the hull in general, which makes the boat stiff.
You can have areas of bulkheads that are cut out or damaged, but in general the more intact they are, the better.
