I don't have much experience sailing, @pclarksurf. But I did notice both those boats appear to have tight mainsail sheets. In my very first uneducated, inexperienced, solo sail in a little fiberglass dinghy (with no flotation) on Lake Arrowhead, I was out in the middle of the lake when I was slammed by a gust that hit me over the port. I was seated on the port side facing starboard and all of a sudden my beautiful mountain view turned to lake water. I panicked and let go of the tiller AND the main sheet and dove for the bottom of the boat. It righted immediately.@Gene Neill on the second photo: any idea on the circumstances that is keeping her on her side? or was that just the magic snapshot at the exact moment before she righted? wicked curious......
I'd say someone got lucky with the timing of the photo. We got knocked down like that once, and it SEEMED like it took an hour for the boat to right herself, but it was probably five seconds or less in reality. We both found ourselves standing side by side on the now-horizontal side of the opposite bench, just like in the pics ... I won't say frozen, but definitely sort of stupefied, watching water pouring over the coaming, submerging the jib winch. Everything was in slow motion. I SHOULD have been scrambling up over the rail to go stand on the keel or something, but things got normal before the thought even occurred to me.@Gene Neill on the second photo: any idea on the circumstances that is keeping her on her side? or was that just the magic snapshot at the exact moment before she righted? wicked curious......
Gene, that's hilarious!My buddy was somewhere forward, trying not to lose his beer. He actually did succeed in saving it, and was justifiably quite proud.
MOST times have I have dumped small dinghy sailboats, due to pushing the limits, I have been able to simply climb up onto the high side, stand on the keel, and assist it in coming upright.. Without the boat flipping completely. That's with 2 people on a un-ballasted boat around 16ish feet, with the hull floating high on the water, and the mast sloped down towards the water.Is there any way to climb up on the high side without shifting weight in the wrong direction?
Yeah baby!I wonder if you could do it just like a dinghy, and avoid getting wet, by simply climbing onto the hull/keel as the boat lays on her side, and climb back in as she comes up ? LOL Maybe @Gene Neill can test it for us.![]()
Does anyone know if Catalina has published a righting moment graph for the boat with keel lifted as well as with keel extended? My take on this would be that a designer would not design and allow to be manufactured for sale to the worlds populations without it being safe to use.Just for some "drinking coffee before bed" curiosity... I tried do an Angle of Vanishing Stability (AVS) calculation for a Swing keel C22 based on a guesstimate of hull draft (draft of the hull - keel), and the numbers here: https://en.wikipedia.org/wiki/Catalina_22 but the result was obviously wrong. Maybe I need tea, or sleep, instead.![]()
I learned to sail on a Dabchick dinghy single handed which my Dad built from wood for me when I was around 8 years old! I quickly learned to let go the main sheet or get wet in heavy winds! Its basically a big surfboard with a mast on it! I think that all sailing training should start with a few hours in a dinghy sailing boat. That would be a law if I had my way. I later progressed to a Laser 1 dinghy at about 12 y/o and later onto what I know as a GP 14 (a red bell shape emblem on the sail). A heavy 14 foot dingy that I did not have the weight to right after capsize so my mother was my crew... hope she does not take that the wrong way! Again sail control was paramount and competitive racing at National club levels was a very steep learning curve. We used to race alongside the Enterprise dinghies as similar in class but they were much more lightly constructed than our heavy GP14.I don't have much experience sailing, @pclarksurf. But I did notice both those boats appear to have tight mainsail sheets. In my very first uneducated, inexperienced, solo sail in a little fiberglass dinghy (with no flotation) on Lake Arrowhead, I was out in the middle of the lake when I was slammed by a gust that hit me over the port. I was seated on the port side facing starboard and all of a sudden my beautiful mountain view turned to lake water. I panicked and let go of the tiller AND the main sheet and dove for the bottom of the boat. It righted immediately.
Just as my heart rate normalized and I was tightening the main sheet, A gust hit me from the starboard side and my view turned to blue sky. I repeated the same maneuver with the same result.
When I took a sailing class in '99, the first thing they had us students do was turtle the self-bailing Holder 14. First step to righting the boat was to uncleat the mainsheet if not already done. Next step was to go stand on the centerboard to lift the mast and start righting the boat.
If the main and jib are still tight, the wind may be able to keep the C-22 on edge. The second pic looks like the port vents are taking on water, but that may just be a coincidence. My guess is the boat just went over. I'm puzzled that both skippers are standing up. Maybe they are trying to close the companionways. I'd be freeing the main and jib sheets and get to the keel if it didn't start righting. But maybe more experienced sailors would advise otherwise.
I have a '76 with the flotation foam. I don't like it, but have yet to sail this boat. I don't like it because is has become very porous after this long. It has become wet when I don't keep the scuppers clear, and it stinks. When I do have to pump the hull, water will slowly reappear over the next few days as it leaks out of the foam that I am told DOES NOT absorb water. When I ask advise about removing the foam, most advised me to just leave it. Considering how long I "THINK" about stuff before I actually do anything, the foam is still in the boat. Some may call my time to think by another less positive term. While watching one of the famous dvds from Catalina Direct, Trim pointed out some nasty looking foam that was installed as an option at the factory. He said that it has deteriorated and should be removed. Now I have to think some more. I again am asking for advise, should I remove this drippy, smelly foam or leave it? If I ever do get to put this boat in the water, I would like for it to smell pleasant. I am not really worried about sinking. I would especially like to hear from others who have dealt with this foam. As for the OP, I don't think that your new installation will exhibit these same problems as my 40 year old foam is showing.
That one pic of the guy hanging on is from the Catalina Org. mag cover.I never saw that pic of Bilbo's before!
With my most erudite observation on a locking screw stopping the possibility of the 550 lb keel dangling about....Nopey.My boat is not fitted with any sort of keel locking screw... but is it actually a practical solution?
