broken stern pulpit
321
catalina 25, 30 montauk / manhattan
stern pulpit port forward stanchion snapped at the top of the base; going to remove and have repaired with a weld.
question is assuming this is from wear and age ('81 cat 30) is it possible and make any sense to have "preventative" welds done on the other stanchions? is there anyway to test the strength of each?
thanks
Oct 18, 2010
58
Anon Anon Anon
You sail your boat down to the islands? Replace them all...
You weekend sailer? Fix the one thats broke and dont worry about it...
Nov 6, 2006
10,254
Probably a bad weld from the factory. Inspect the others carefully, looking for cracks.. if you find some, then repair those. The welder will have "dye penetrant" for inspection, ask him to check them all.
Ross
Jun 15, 2004
14,693
For a dye penetrant test kit, use diesel fuel and liquid white shoe polish. Paint the suspect with diesel fuel and allow to soak for a few minutes and wipe dry. Then paint on the white shoe polish and allow that to dry. if there is a crack the fuel oil will stain the shoe polish.
