As the photo shows below, I have a fiddle/becket/Vcam block that is being used to adjust my backstay and the bearings have started to break up. I thought I could replace the sheave but looking at it, the sheave doesn't appear to be removable. I have a couple questions. #1. Is this a common piece of hardware to use at the backstay adjuster? It has worked fine for me but it's certainly something I'm not too familiar with. I think I'd rather use this block with a V cam rather then drill more holes and put a camcleat or something on my transom. #2. Is there any reason this is a double? I don't see the need for both sheaves. Its not set up now using both and the pull is fairly light.
Do I replace this piece with the same or have you guys got better ideas.
Oh btw...this is on a Cal 2-27.
[url=http://
Thanks
Jared
[url=http://
Thanks
Jared
