Bridle Hoisting a Hunter 216?
Aug 17, 2026
11
Hunter 216 MBYC
Ok, so thinking about a 216 and we use hoists at my yacht club to launch. I’d use a bridle attached to chainplates and rear cleats with backing plates. Wondering if anyone’s been doing this and for how long. I’m a little concerned that the composite material might get stress cracks from doing so. Thoughts?
3,667
Significant backing plates on the stern cleats and a spreader bar across the "V" that lifts the boat. Lifting wires that are not vertical multiply the force on the attachment point. A spreader bar keeps the boat from getting squeezed.
Are both the bridles going to a single point on the hoist or is there a bar longitudinally?
3,667
To a single point.
A lifting bar may make sense for y'alls operation.
I'll post a picture of the one I had made. It is for lifting our coach boats and are much heavier than your boat but gives you an idea.
A spreader bar does not have to be anything more complicated than a 4X4 with a couple of eye bolts at the same distance apart as your cleats or chainplates.
Aug 17, 2026
11
Hunter 216 MBYC
Ok, so a spreader bar makes sense to spread the load between the chainplates. Do you do anything from the front to rear? Pics of your setup would be helpful, thanks!
Aug 17, 2026
11
Hunter 216 MBYC
So that runs bow to stern with two more going across the boat to attach where the shrouds meet the deck and the other attached to the two stern cleats?
