Well my new EV-100 wheel pilot worked great for about 1½ hours.
Then I turned it to standby and back to auto and got an error "NO DRIVE DETECTED". The manual said that error was due to a bad connection between the ECU and drive but the wire is very well protected and nothing was in that area in the 5 seconds between working and error.
I removed the wire connector from the drive and reinstalled. Nothing.
I tested that two connectors for voltage when I ingaged auto. Nothing.
I tightened the connection at the ECU. Nothing.
GRRR!
GRRR!
I had power to the plotter so there was no reason to check the fuse in #2, right?!?!? D'oh!
