New Catalina
Oh Boy Tim. Where do I start. I have been holding off, but now seems as good of time as ever. My brand new Catalina 387 has been nothing short of a nightmare. The first thing that happened was the running out of fuel in the middle of the Chesapeake Bay with 3/4 tank indicated on the gauge while trying to come back in without cooperative winds and little room or time for tacking; after all, that's what an aux is supposed to be for. Bad sending unit and gauge. Next, the bolts that connect the output shaft to the sail drive fell out and wound up under the motor. The battery selector switch was wired backwards and would drain down the opposite battery while showing full charge on the battery I thought I was using. The sales rep claimed there was no sea strainer, which caused the engine to overheat, thanks for the hi temp alarm, since the temp gauge turned out the be defective as well. There is no mention in your owners manual of the location of the sea strainer, or at least in the one for my 387. The UV protector de-laminated on the main sail which is on an in mast roller furler. When we dropped the main to send in for repair, the halyard is chewed up and ready to break from something in the top end of the mast that has chewed through the halyard line. This was by the way the first time the sail had been dropped or the halyard moved since it was installed. The neutral leg of the ship to shore connector on the boat melted and almost started a fire which I found on the 15th of Feb this year. This was a Hubble connnector. We have replaced it with a Marinco which seems to have much safer design features to contain the stranded wires. The wire was installed at the factory in Florida on the wrong side of the lug, so that when the lug was tightened, it turned the wire off the lug instead of drawing it in. (Should be wrapped clockwise instead of counter clockwise). Other than that, and a few minor situations with the Knot meter and water temp gauge on the knot meter for the bay water temp being off, it has been lots of fun. We have not had her in the water one year yet and we have put just under 1000 nautical miles on it learning the boat and our Chesapeake Bay. Would I ever buy a brand new Catalina again. NEVER, NO WAY, NOT NO, BUT H**L NO. Would I recommend a new Catalina to a friend, No Way would I put my reputation on the line for them. I do love this boat though and I bet that this can happen with almost any new boat, just like a new car. Quality Control has gone out the door just like customer service here in the good old US of A. They have been replaced by pursuit of the almighty dollar. What I have done is learn to not rely on any gauge, but on charts, physical measurement and inventory and the use of a good watch, compass and common sense. Hopefully, mine was one of those outside the 3 deviations of the norm under the curve and you will have nothing but a fantastic season. I do need to put in a plug for my dealer, Chesapeake Yacht Sales; they have been super on doing the warranty adjustments, without them I would have insisted on my money back. This was not a cheap boat and none of this should have happened. Good luck, fair winds and following seas my friend, welcome aboard!
