I have a philosophical question about 12V wire on a boat and I didn't want to hijack the other thread on 12V wire so I started a new thread.
So here is my question. If you have a trailer sailboat that does not spend most of its time in the water (i.e. it is not in constant motion) is the use of tinned, braided wire overkill?
:stirthepot:
I've rewired 4 boats now and each time I did so, I tried to use the best practices. I got the good wire, used terminal connectors, shrink wrap etc. But is this a case of there being three options....
1) good enough,
2) better and
3) best
And we often opt for best when good enough is .... well.....good enough?
I know the DIY snobs are cringing right now but follow me for just a moment.
If I were to use solid wire (I didn't) and support it every few inches (I always do), how much motion would the wires actually experience?... for a trailer sailor/day sailor with a boat that sits on a trailer all but 20 to 30 days out of the year... the wires would experience the equivalent of one month of motion per year... how long would it take for the motion of the waves to break one of those wires... I'm thinking not in the life time of the boat. Even if you want to throw in the motion of trailering the boat.... there would not be enough motion to break those wires. So if we take breaking the wire out of the equation we are down to corrosion as an issue...(tinning and wicking). A solid wire would have a lot less surface area = less wicking... so can we assume a slower rate of corrosion (am I thinking about this correctly?). And on top of that, we are back to that 20 or 30 days/year exposure issue so less corrosion overall....
I'm not trying to make an argument for doing a sloppy job. I ceratianly see why a boat that sits in a slip has a lot more to contend with that one that sits on a trailer in a garage most of its life. I'm just wondering if there aren't times when we engage in overkill on our DIY boat projects. I'm thinking of the low budget day sailor who picks up a $1000 boat on Craig's List and wants to rewire the navigation lights. Cheap solid wire with good waterproof connections would seem to make sense in a situation like that. Why spend a $100 when $30 will do the job?
Sacrilege? .. let the @ss kicking begin
