Bottom paint
2
Oday 28 Duxbury, Ma
Am planning for Spring and ready to buy bottom paint for my 28' O'Day...thinking of Pettit Hydrocoat...any comments on choice...also how many gallons needed for 28' hull.
thanks
Oct 29, 2012
354
Catalina 30 TRBS MkII Milwaukee
What's on the bottom now???
If you go to Interlux web-site, the offer recomendations for coating over previously painted surfaces.....
Some paints do not bond to others,
Jun 28, 2009
104
1984 O'Day 28 Bath, NC
Hello John,
It depends on what you have on her now as to what you can put on it. Some paints you can't put over others. That being said I just did a bottom job a month ago. My choice was Interlux ACT, its an Ablative. It took 1 and 3/4 gallons for 2 coats with a 3rd coat on the leading edges.
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
I just got the new practical sailor and they tested bottom paint. Highest rated was Petit trinidad and Interlux Ultra with biolux had a recommended rating. I have used Ultra for the last two years with very good success in horrible fouling waters. I may have to haul this spring for a new coat or two. NONE OF THE WATER BASED PAINTS WERE RECOMMENDED. Lucky to get a year and a half of protection.
Oct 29, 2012
354
John,
Where do you sail ??? Here in the Great Lakes VC 17 is perfered by alot of sailors.....
BarryL
May 21, 2004
1,085
No to hydrocoat
Hello,
Over the years I have used various Pettitt paints on my boats. I tried Hydrocoat and one year was enough. It didn't work well at all and didn't last long either. I now use Ultima SR40 and it works well for two years. I sail on the Long Island sound and the boat is in the water from May to November and on land during winter. I apply two coats and after the second season the paint is just about worn off. I do a light sanding and then another two coats.
Good luck,
Barry
thanks
May 24, 2007
185
Beneteau 352 Milwaukee, WI
Re: What's on it now . . .
His profile says he's from Duxbury, Ma. That would be the NW corner of Cape Cod Bay. So he is in a cold water, salt water environment.
John - What you have on the hull now will likely influence what you can put on this spring (unless you sand off all the old stuff first).
