It turns out the link I provided earlier to an interesting paper was a cut down version of the one I wanted to show.. here is the one with the more detail
http://analogengineering.com/lightning/lightning_rod_study_1.pdf
This is just playing with numbers which may not really mean anything but here is another way to look at ungrounded vs grounded masts and also what do the wire brush things actually do.
When you place a metal conductor such as a mast in an electric field, the conductor has only a single voltage over its length so the ends of it end up with enhanced electric field and if the fields are high enough, this creates corona current
http://en.wikipedia.org/wiki/Corona_discharge In a few words, the high field at the end of the conductor (mast in this case) causes electrons to be ripped from an air atom and the electron accelerates to the mast and the left over positive air ion drifts up and away. If you read the paper above, its talks about the corona current in a little more detail but the corona current pulses and the rate is audible - explains the buzzing people hear on sailboat rigging during a lightning storm.
The wire brush things have lots of sharp points at the end of the mast so are likely good at creating corona current. So these strip off electrons from air atoms, the positive air ion floats away and the electron goes to the mast.
What the electron going to the mast does is if the mast is not grounded, it looks like a capacitor. So the electron that was added to the mast by corona current charges the mast capacitor according to coulombs law.
As electons are added and the mast capacitor is charging, this raises the mast voltage potential - which then decreases the potential to ambient at the top of the mast but now starts to increase the potential to ambient at the bottom of the mast. At some point, a corona current will begin to also flow at the bottom of the mast and when the corona currents at the top and bottom of the mast are equal, the mast potential stops changing. If we assume equal corona mechanism at the top and the bottom (probably not exactly true), the mast will charge to the ambient electric field at its mid point.
Now.. using some numbers from the link.. Before a strike and when the wire brush is working to charge the mast by corona current (actually any sharp point on the mast will do the same thing), the ambient electric field is around 5 KV/meter. So for either a grounded mast or an initially uncharged not grounded mast, the potential between the top and ambieint at 10 meters high is 50 KV (10 meters @ 5KV/ meter).
Now we let the ungrounded mast charge up to the potential at its mid point which would be 25KV (5 meters @ 5KV/meter). Now the top of the mast is only 25KV different than the ambiet field potential.
So the grounded mast has a higher field at its tip - so has higher corona current - which according to the paper, can delay the formation of an upwards streamer.
Now the interesting thing is that when the lightning gets close to the ground, the fields required for a streamer to propogate are 440KV/meter. Ie, the field went from 5KV/m before the strike to 440 KV/m when ground leaders can propogate - a huge difference.
At 440KV/meter, the ambient potential at the top of the mast at 10 meters is 4400 KV.
This potentail at 10 meters of 4400KV compared to the really small 25KV or 50KV of the grounded or ungrounded mast before the strike makes what happened with the mast before the strike came near the mast pretty much insignificant. The differene in the mast potential for grounded or ungrounded conditions is only 0.56% of the potentail when things really matter - just before the strike.
This is another completely unprovable argument that grounding or not grounding doesnt really make much difference.
It also shows why the wire brush deals also really dont make any difference in your chances of getting struck although since that paper showed a difference between a sharp or blunt tip in formation of a leader, maybe the wire brush makes some difference here. The argument that it "discharges" the mast is not at all correct.. these are actually adding charge to the mast but corona current will occur with our without the wire brush.
