Boat Pulls to left when Motoring
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Take my word for it strut can be bent without pulling it out of the hull AND without bending the shaft. Don't ask how I know this....
I'd also suspect the strut. It could certainly be misaligned without bending the shaft or prop.
Ken
I thought all boats pull a bit to the right/left when under power. It is the nature of a single prop. Why big stink pots and Navy ships use two props counter rotating..
It issue is the amount of pull.
My bad. So the haul out is suspect, changing something in the stream. I bet that is why they have you sign all those waivers when they wheel the big crane above your boat.
Dec 13, 2010
123
Hake 32RK Red Bank
It did vibrate-about like when cutless bearing goes bad- but not so bad I couldn't drive it the three miles for haul out.
