Boat Pulls to left when Motoring
Nov 26, 2012
1,654
C&C 40-2 Berkeley
I recently hauled my '84 Hunter 34 to do a bottom job. I did it myself. Sanded. painted. Buffed. Replaced zincs. The yard put the boat back in the water when I was not there. The first time I took it out it pulled to the left in a big way when motoring. In neutral it goes straight when coasting. There was no hint of this before. What could have happened? I dove the boat and could not see anything wrong. It was a quick look so I did not expect to. What can cause this? Any ideas?
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
I would suspect the launch crew has knocked your prop out of alignment. Chief
Hunter 34 Alameda CA
Is there any way that the rudder was over driven so what you used to have as center is no longer?
Edit: well probably not as it coasts straight. More likely what Chief RA said. Any vibration at wide open throttle?
Maybe they bent the strut.
capta
Jun 4, 2009
5,006
Have you operated the boat with a clean prop and bottom before?
Most sailboats do what you are describing because the prop and strut are slightly offset to facilitate removing the shaft without removing the rudder.
-na -NA Anywhere USA
I would check the prop and strut to see if any strap was placed on that. It happens at yards.
Chief RA; Long time no talk to. Hope you are doing well. A new one on me that I set the brush on fire with a crowbar. Got burned of course but a crowbar? Catching fish with a car and other things, boy I have pulled some stunts over the years.
Crazy
SFS
Aug 18, 2015
2,088
Currently Boatless Okinawa
If you are going to that much trouble, might as well move the rear tires to the front, and the fronts to the rear. Helps equalize the wear.
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
How? By bending the shaft? Seems like there'd be other noticable issues besides a pull to one side or other. Like vibration.
Nov 26, 2012
2,315
fstbttms: Note that there is no indicator of whether it vibrates or not. If the stern lift strap slips, guess where it ends up. Chief
Feb 26, 2011
1,440
My point is that the only way that the prop is "out of alignment" is if the shaft was bent. If the shaft was bent, it seems likely there'd be other, very noticable indicators that this was the case. I don't believe the strut could be bent without it pulling out of the hull.
May 24, 2004
7,202
CC 30 South Florida
Had a similar occurrence once but never figured out the cause. Our diver had just cleaned the bottom a few days earlier and I asked if perhaps the prop had not been cleaned. The diver indicated that he had indeed cleaned the prop and that he had not noticed anything out of the ordinary. Since in neutral or under sail the boat tracked good I surmised the problem was not with the rudder but something with the engine drive train. I also felt the engine was lacking power and smoking a little which reinforced the theory of a fouled prop. I went ahead and replaced the fuel filters, adjusted the valves lash and changed the engine oil. Next weekend we went out and the problem was gone. Don't know if it was an engine torque issue or if the diver came back during the week to correct something he had done. Check the sacrificial anode and the balance on the prop.
Kermit
Jul 31, 2010
5,713
True true. But that's what my tire guy normally tries first. And I trust him. I get 75,000 miles from my 35,000 mile tires. I keep them at 40 lbs of pressure per his recommendation.
Nov 26, 2012
1,654
C&C 40-2 Berkeley
There may actually be some vibration that was not there before. It was the first thing my wife noticed. This weekend I may dive the boat with the engine running and in gear to see if there is any wobble. Fstbttms: Is that safe or completely crazy?
As for my tires, I drive a pickup so I definitely rotate them back to front but I never switch left to right.
capta
Jun 4, 2009
5,006
completely crazy!
Feb 26, 2011
1,440
I've done it many times. Just be well clear of the prop and off to one side.
Beneteau 323 Annapolis MD
Is there a chance some of the steering linkage slipped a bit? On my B323 I centered the wheel and made adjustments until the quadrant was also centered. Then, I took the boat out on auto pilot to make sure it tracted straight.
UPDATE to add... if it does not go straight, adjust the cables to move the rudder as needed.
123
Hake 32RK Red Bank
Take my word for it strut can be bent without pulling it out of the hull AND without bending the shaft. Don't ask how I know this....
